Home » Car Questions » 1998 ford ranger v6 3.0
1998 Ford Ranger
So it idles OK but when I step on it, it sputters and then it stops once I get up to speed or when I put a load on it Going up a hill???
1 thought on “1998 ford ranger v6 3.0”
  1. Most likely a misfire in the engine. A good thing about a Ford is once it does it long enough it will set a code and illuminate the check engine light. A scan tool id required to pull the codes or you could have just about any local auto parts store do it for free. The code will pinpoint the particular cylinder that is causing the issue. It may just throw up a Random Misfire code P0300.
    P0300 Ford – Random Misfire Detected
    Possible causes
    – Faulty spark plug (s)
    – Faulty ignition coil (s)
    – Intake air leak
    – Incorrect fuel pressure
    When a misfire occurs, engine speed will fluctuate. If the engine speed fluctuates enough to cause the Crankshaft Position (CKP) sensor signal to vary, the Engine Control Module (ECM) can determine that a misfire is occurring.
