2008 chrysler 300c
wont start .where is reset button fuel pump running in start up prestart. got spark but no fuel
2008 Chrysler 300
1 thought on “2008 chrysler 300c”
  1. Does it run if you spray starting fluid in the air filter?
    You will need to determine if you have fuel pressure and if you also have fuel injector pulse.
    No reset button like on fords, it has the fuel pump, fuel pump relay, one fuse #6 (20A) and the ECM.
