1996 mercedes 220
1996 Mecedes 220
Does the ignition switch turn off all the power to the car? when off windows, lights etc still work
1 thought on “1996 mercedes 220”
  1. No it does not. It is normal for the headlights and taillights to still operate along with the hazards. However it is not normal for the windows to still have power. This sounds like your ESA relay is sticking. Replacing the relay should take care of that. If you find the relay is fine and it may be more of a wiring issue I will provide the wiring diagram to help save you some time.
    1996 Mercedes 220 Power Windows Wiring Diagram
