When the car gets warmed up after 10 to 15 minutes of driving, when you push the gas, no gas is going through to accelerate. We have changed the fuel pump and fuel filter still happens. What could be the issue.
First, if the check engine light is on you will need to pull the diagnostic trouble codes. Just about any local auto parts store will do this for free. Then post any codes below so we can dig further to the issue.
No codes. It may be a temperature sensor reading improperly. Or an O2 sensor sticking or some other failing sensor like the MAF Sensor.
