GMC
StabiliTrak 2007 GMC Sierra club cab
2007 GMC SierraKeep getting a ‘stabiliTrak service and service traction’ error message. The ‘brake pedal sensor switch’ has been replaced and now the message appears only when the engine is idling for more than a few minutes (disappears once I start driving). What could cause the message to keep appearing?
My first guess would be a faulty sensor or sensor connection. However some hands on testing would be needed to locate the issue.
This vehicle is equipped with a BOSCH ABS/EBD/TCS/VSES brake system. The electronic brake control module (EBCM) and the brake pressure modulator valve (BPMV) is serviced separately. The BPMV uses a 4 circuit configuration to control hydraulic pressure to each wheel independently.
The following vehicle performance enhancement systems are provided.
Electronic Brake Distribution (EBD)
Power Brake Booster Solenoid Vacuum Supply
Traction Control System (TCS)
Vehicle Stability Enhancement System (VSES)
StabiliTrak® Indicator Light
If equipped, this warning light should come on briefly when the engine is started.
If the warning light does not come on then, have it fixed so it will be ready to warn you if there is a problem. If it stays on, or comes on when you are driving, there may be a problem with your StabiliTrak® system and your vehicle may need service. When this warning light is on, the system is off and will not limit wheel spin. Adjust your driving accordingly.
This light will also flash when the StabiliTrak® system is active.
If the StabiliTrak® system warning light comes on and stays on for an extended period of time when the system is turned on, your vehicle needs service.
Service StabiliTrak Message
The message center displays the service stability system message when any one of many VSES-disabling DTCs is set. The EBCM sends a serial data message to the IPC requesting this display.
Service Traction Control Message
The message center displays the service traction control system message when any one of many traction control – disabling DTCs is set. The EBCM sends a serial data message to the IPC requesting this display.
StabiliTrak Off Message
The message center displays the stabiliTrak off message when one or more of the following conditions exists.
The transfer case is shifted into 4 LO. The EBCM sends a serial data message to the IPC requesting illumination.
The driver manually disables the VSES and engine torque reduction by pressing the traction control switch. The EBCM sends a serial data message to the IPC requesting illumination.
The estimated temperature of any solenoid coil exceeds an acceptable limit. The EBCM sends a serial data message to the IPC requesting this display.
The EBCM detects a failed brake switch. The EBCM sends a serial data message to the IPC requesting this display. A DTC sets when this condition exists.
VSES sensor initialization time is excessive. The EBCM sends a serial data message to the IPC requesting this display.
Serial data communication between the EBCM and any of several other control modules is interrupted. The EBCM sends a serial data message to the IPC requesting this display or the IPC displays the message when communication with the EBCM is interrupted.
The PCM is not able to perform engine torque reduction. The EBCM sends a GMLAN message to the IPC requesting this display. DTCs set when this condition exists.
The EBCM detects an excessively low or excessively high ignition voltage. The EBCM sends a GMLAN message to the IPC requesting this display.
Vehicle stability enhancement system (VSES) provides added stability during aggressive maneuvers. Yaw rate is the rate of rotation about the vehicle’s vertical axis. The VSES is activated when the electronic brake control module (EBCM) determines that the desired yaw rate does not match the actual yaw rate as measured by the yaw rate sensor.
The desired yaw rate is calculated by the EBCM using, primarily, the following inputs.
The position of the steering wheel
The speed of the vehicle
The lateral, or sideways acceleration of the vehicle
The difference between the desired yaw rate and the actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. When a yaw rate error is detected, the EBCM attempts to correct the vehicle’s yaw motion by applying brake pressure to one or more of the wheels. The amount of brake pressure which is applied varies, depending on the correction required. The engine torque may be reduced also, if it is necessary to slow the vehicle while maintaining stability.
VSES activations generally occur in turns during aggressive driving. When braking during VSES activation, the pedal may pulsate. The brake pedal pulsates at a higher frequency during VSES activation than during ABS activation.
VSES Sensors Initialization
The vehicle stability enhancement system (VSES) sensors values may vary slightly due to differences in temperature, sensor mounting, connector resistances, manufacturing, etc. Since VSES is a very sensitive and precise control system, it is imperative that the electronic brake control module (EBCM) be able to accurately equate a given sensor voltage with an actual unit of measurement. For example, the yaw rate signal of one vehicle may be 2.64 volts at +18.0 deg/sec yaw rate while the yaw rate signal of another vehicle may be 2.64 volts at +17.5 deg/sec yaw rate. Therefore, at the beginning of each ignition cycle, the EBCM must perform an initialization procedure to observe how the VSES sensors are correlated with each other and also to determine what each sensor value is when the applicable unit of measurement equals 0. This voltage is referred to as the sensor bias voltage. Although some activation of the VSES system may occur if required to prior to full initialization, the system does not give optimum performance until the sensors are fully initialized.
The following VSES sensors require initialization:
The yaw rate sensor
The lateral accelerometer
The master cylinder pressure sensor
The steering wheel position sensor
When the vehicle speed is greater than 25 km/h (15 mph), full sensor initialization must occur during 3 km (1.8 mi) of driving or 1 km (0.6 mi) of straight and stable driving, whichever occurs first. Although an attempt at initialization may fail due to driving conditions, such as driving on a very winding road, failed initialization is usually caused by a sensor bias voltage which is not within an acceptable range. Often, a DTC sets soon after a failed initialization attempt. The message center displays the stability system disabled message when sensor initialization fails.
Kathy Brueggemann
Recent My Questions
2008 Chevy Colorado Headlamp Bulb Replacement
Removal Procedure Caution: Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass…
2 weeks ago
1991 Dodge Dakota 5.2 surges at low rpm
My vehicle surges at low rpm. There are no vacuum or fuel leaks and a new IAC made no difference.…
2 months ago
How to Replace Thermostat 3.6L Chevy/GMC – Code P0128
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
7 months ago
Jeep Wrangler TJ 97-2006 Clutch Replacement
Removal & Installation Remove transmission. If original clutch cover will be reinstalled, mark position of cover on flywheel for assembly…
7 months ago
Fuel Pump Driver Module (FPDM) 2014 Ford Explorer 3.5L
Engine has no codes. Scan tool shows cam and crank correlation are good. Fuel pressure from pump is at 60…
8 months ago
Just put these sick headlights on my Jeep Wrangler
Headlamp Bulb R&R Warning: halogen bulb contains gas under pressure. bulb may shatter if glass envelope is scratched or if…
9 months ago
