I’m getting code p0351
I’m getting code p0351 from my 2007 Ford Crown Victoria Police Interceptor and I’m wondering what it means and what I need to do to fix. My car drives really ruff and horrible on gas since this code appeared. Please help registration is due in June probably will not pass smog.
Ford Code P0351
Ignition Coil ‘A’ Primary/Secondary Circuit
Each ignition circuit is continuously monitored by the Engine Control Module (ECM). The test fails when the ECM does not receive a valid pulse signal from the ignition coil.
Ford Code P0351 Description
The ignition system on the vehicle uses individual ignition coils for each cylinder. The Engine Control Module (ECM) controls each ignition coil operation. The ECM sends a ON/OFF signal to energize the ignition coil to create a spark at the spark plug when a spark is required at the cylinder.
Ford Code P0351 Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- Engine may be harder to start
- Engine hesitation
- Rough engine idle
