2005 Mitsubishi Galant Radio
Mitsubishi Galant
Radio comes on but no sound, is this the amp? if so where is it located?
The amplifier is part of the radio unit itself on some models and separate on others.
Replace Radio
1.Pry off center radio panel using a suitable tool.
2.Remove radio bracket attaching screws, then disconnect antenna and radio electrical connector.
3.Remove radio.
4.Reverse procedure to install.
