My car is stuck in park Volkswagen EOS 2007
2007-vw-eos
My car is stuck in park after shifting into park while car was rolling. help!
Have someone or a few someones push the vehicle with uphill pressure while you remove it from park. Another alternative would be to block the rear wheels and jack up the front and then take it out of park. Anything internal may require an in depth inspection. If the battery is dead or there is an issue with the shift interlock solenoid you may need to do it manually. The video will show how to pop the shifter panel to gain access to the interlock solenoid and what to do next.
How to get Volkswagon EOS from park to neutral
How to get a 2009 Volkswagen Eos into neutral
