2014 Ram LED parking light repair
2014 Ram
I lost the front 3LED parking light on the right. Without replacing the entire assy what value resistor can I replace it with. I’ve already tried 1k/660/440/330/and 220 ohm. What is the parameter the BCM will accept??
I am showing these LED Bulbs will fit and are easy enough to swap out. These are for the style Without projector-type headlamps model only, fits front and rear turn signal light, brake light, tail light, parking light. Might need load resistor to avoid signal hyper flashing.
Not exactly sure of the correct value resistor you would need. I will go ahead and post this so others that read it might be able to share that information.
1 thought on “2014 Ram LED parking light repair”
  1. Sankz for the feedback. My entire headlamp is a SEALED unit. I only reached the wires by cutting them through a small hole and feeding them out through a drilled hole. I already joined you site, Thanks for the effort but I don’t think you can help. I probably need an electronics expert as mMOPAR obviously didn’t want me the replace these without replacing the entire assy.I’ve scoured the internet and apparently there mare too many variables for me to get an answer. And by the way you attachment was a SAD FACE saying I couldent view it.The world needs more folks like you …thanks again.
