Use a multi-meter to check the ohm’s of the chip in the ignition key. Then trip over to Radio Shack and buy a resistor with the same ohm’s reading. (couple bucks). Connect it where the two tiny wires meet at the ignition key tumbler in the steering column and your all set.
misti
How can I bypass or just unhook the security system?
