Home » Car Questions » 2001 Saturn .sc1
2001 Saturn .sc1
Car will start fine when engine is cold but after it warms up it will turn over but won’t start . Please help
1 thought on “2001 Saturn .sc1”
  1. First thing I would like you to try the next time it is warmed up and decides not to start, Hold the gas pedal to the floor and try to start the engine. If it starts up, replace the IAC (Idle Air Control). If it still won’t start you may need to pull the computer codes to help determine the next move. No codes, it will most likely be the Ignition Control Module that will need to be replaced.
