Clutch is slipping can I adjust it
duct control stepper motors? HVAC Air Door Actuator R&R Warning: On vehicles equipped with air bags, disable the air bag…
Removal Procedure Caution: Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass…
My vehicle surges at low rpm. There are no vacuum or fuel leaks and a new IAC made no difference.…
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
Removal & Installation Remove transmission. If original clutch cover will be reinstalled, mark position of cover on flywheel for assembly…
Engine has no codes. Scan tool shows cam and crank correlation are good. Fuel pressure from pump is at 60…
View Comments
The Clutch on this vehicle is Hydraulic and is self adjusting. There is no adjustments that can be made.
If the clutch is slipping then it is time to replace the clutch disc and pressure plate assembly.
If you find it difficult to get the transmission into gear, the most common reason is a failed Clutch Master and or Slave cylinder assembly. I recommend replacing both at the same time and when possible, get the complete assembly from a dealership as they come pre-bled.
