2012 ford rangerJuly 30, 2014the compessor clutch cycles on and off every few seconds not allowing the system to cool completely Keywords:Rangerrelay switch location 1 thought on “2012 ford ranger” Freeautomechanic July 31, 2014 at 10:01 am What you are referring to is commonly called “short cycling”. Most common cause for this would be from a lower amount of freon than needed. Have the Air Conditioning systems freon level topped off and you should be good to go. Comments are closed.
