I have multiple issues going on with car. The main question that I have, is: If car stalls, and won’t move, or even when it seems to be running ok, does this necessarily mean that I have tranny problems ? Some of the probable other issues that I think might be relevant. Cylinder head probably blown. Vacuum lines either hooked up wrong, or not at all. Significant coolant leaks, so not able to use a core tester.
Mechanic has it now, and I’m just concerned about being taken for a ride.
If the vehicle’s engine runs fine and it just won’t move when put in gear. This would point to the transmission. The first thing to check would be the transmission fluid level with the engine running and setting on a flat surface.
What does the fluid level look like? Note the color?
Post your findings in the comments below.
