Honda civic 1998
I have a 98 civic manual. My car seems to shake and turn off on me when i shift gears. When i put it in neutral my car wont shut down on me. I also notice that when i turn on the AC it starts to shake even if it is in neutral and it shuts down.
1 thought on “Honda civic 1998”
  1. something to keep in mind is that the A/C compressor comes on when you turn the A/C on or when you use the defroster.
    If the check engine light is on, pull the codes and post them below. Your local parts store will generally do this for free.
    It could be an issue with the compressor or something else if the check engine light is on. Is it on?
