1997 Lincoln Town car
1997 Lincoln Town Car
In October of 2014 my back left whell feel off due to loose wheel nuts. This has also happened a second time a couple months later but I can assure you that the wheel nuts were very tight. I lifted the car andhad the back wheels spinning at around 35 miles per hour you could see it wiggle and when brakinth the wiggle worse. I put a spare tire on it to see if the rim was damaged but I got the same results. during both of the incidents I was traveling at around 35 to 40 miles an hour and fell on the rotor which has also been replaced along with the brake pads. I want to diagnose this as a rear axle?
1 thought on “1997 Lincoln Town car”
