My car has been making a tapping noise in the front end, it’s mostly on the right or in the middle under the dash. It sounds like someone is tapping. What could be causing this noise? It happens when I first turn on the car and while in motion.
ford 2008 taurus
This is from an actuator trying to reset itself and it is unable to. The actuators are used on the air conditioning mode doors. They are used to change from hot to cold and from defrost to dash to floor. You would need to dig into the dash to determine which one it is and correct the issue. It may be a cracked actuator housing or door mounting.
