Recently my 2004 Acura TL has been cutting off while I’m driving. The lights stay on and everything, which leads me to believe that it is not a battery-related problem. The car will restart with no problem but the same problem occurs.
There is a recall for 2005 for the exact problem. The service bulletin is 05-013….says,
“A loose terminal in the under-dash fuse/relay box may cause the fuel pump to loose power. If the fuel pump becomes inoperative, the engine may not start. In the worst case, if the fuel pump loses power while driving, the engine could stall without warning, and a crash could occur.”
