I have a 2003 Chevy Tahoe. After changing the oil, tire kingdom forgot to reset oil change light also know as the oil life indicator light. They told me how to reset it by turn on the power and pumping the gas pedal four times. A message came up by I cant remember what it said. I turned the car off and didn’t use it til the next day. When I started the Tahoe I had to give it gas to keep it running. I went to leave but it was running really bad acting like it wanted to shut off. When I was stopped I had to rev it up to keep it running. What could be wrong and does it have to do with me resetting the oil light?
Having to reset oil change light is a non intrusive procedure that should bear no effect on the drivability of the engine whatsoever. The procedure simple resets the oil change indicator light.
Removal Procedure Caution: Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass…
My vehicle surges at low rpm. There are no vacuum or fuel leaks and a new IAC made no difference.…
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
Removal & Installation Remove transmission. If original clutch cover will be reinstalled, mark position of cover on flywheel for assembly…
Engine has no codes. Scan tool shows cam and crank correlation are good. Fuel pressure from pump is at 60…
Headlamp Bulb R&R Warning: halogen bulb contains gas under pressure. bulb may shatter if glass envelope is scratched or if…
