Recently I was given the opportunity to try out some new technology by nonda. The truly innovative iHere 3.0 Key Finder & Selfie Remote brings more to the table than anything we have seen before. I won’t go on about all the specifications but I do want to highlight a few points of interest I found. iHere is more than just a tracking device for your keys. This powerful remote has some built in spy tech as well. May be purchased through amazon.
Pros
Cons
Overall rating
iHere 3.0 provides an easy to use selfie remote. Place your phone just about anywhere and snap photos with your iHere 3.0. Great for family photos. Take a perfect selfie or group photo every time. Loss your phone and the iHere can ring your phone to help you find locate it.
Image being able to record from your phone and not even be in the room. You could be at a restaurant with a group of friends and excuse yourself from the table having left your phone behind. Then all you have to do it activate the voice recorder with your iHere 3.0. The entire conversation is recorded and no one is the wiser. The same could be done with the camera on the phone. Big brother doesn’t have to be the only one with cool toys to play with.
Each iHere device is equipped with Bluetooth technology. Bluetooth allows the connection between a Smart Phone and the iHere 3.0 device and acts as a homing signal. A quick download of the app onto the phone and the key finder is ready when you are. Select the “Call Phone” option and have the ability to locate your phone using the remote to ring your phone till you find it. It works just as easy as finding your keys.
– iHere 3.0 Specifications
My vehicle surges at low rpm. There are no vacuum or fuel leaks and a new IAC made no difference.…
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
Removal & Installation Remove transmission. If original clutch cover will be reinstalled, mark position of cover on flywheel for assembly…
Engine has no codes. Scan tool shows cam and crank correlation are good. Fuel pressure from pump is at 60…
Headlamp Bulb R&R Warning: halogen bulb contains gas under pressure. bulb may shatter if glass envelope is scratched or if…
Intake CVVT came apart and blew a hole in the valve cover. How much would something like that cause to…
