Yes, the most likely reason would be a bad starter.
One click is usually a bad starter or loose connection at the battery. However a loose connection is also accompanied with dash lights going out. A bunch of repeating clicks would indicate a bad or weak battery. Since you are experiencing one click and sometimes it starts and others it doesn’t, a starter replacement would be right course of action.
duct control stepper motors? HVAC Air Door Actuator R&R Warning: On vehicles equipped with air bags, disable the air bag…
Removal Procedure Caution: Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass…
My vehicle surges at low rpm. There are no vacuum or fuel leaks and a new IAC made no difference.…
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
Removal & Installation Remove transmission. If original clutch cover will be reinstalled, mark position of cover on flywheel for assembly…
Engine has no codes. Scan tool shows cam and crank correlation are good. Fuel pressure from pump is at 60…
