Auto Repair Questions
2001 Ford Taurus wont start
the car just stopped yesterday . looked under hood and battery cables were corrode and loose. cleaned and tidied them. I know the spark plugs and wires need to be changed but after I cleaned and tided cables it at least started to turn over. but trying to jump it that’s all it would do
Charge or get a new battery
Jackie Shered
Recent My Questions
1991 Dodge Dakota 5.2 surges at low rpm
My vehicle surges at low rpm. There are no vacuum or fuel leaks and a new IAC made no difference.…
6 days ago
How to Replace Thermostat 3.6L Chevy/GMC – Code P0128
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
5 months ago
Jeep Wrangler TJ 97-2006 Clutch Replacement
Removal & Installation Remove transmission. If original clutch cover will be reinstalled, mark position of cover on flywheel for assembly…
5 months ago
Fuel Pump Driver Module (FPDM) 2014 Ford Explorer 3.5L
Engine has no codes. Scan tool shows cam and crank correlation are good. Fuel pressure from pump is at 60…
6 months ago
Just put these sick headlights on my Jeep Wrangler
Headlamp Bulb R&R Warning: halogen bulb contains gas under pressure. bulb may shatter if glass envelope is scratched or if…
7 months ago
Hole in valve cover 2017 Hyundai Santa Fe
Intake CVVT came apart and blew a hole in the valve cover. How much would something like that cause to…
9 months ago
