This is most likely coming from the rear differential. Specifically the pinion shaft bearings. Drain a little rear end fluid and look for the gear oil to has a shinny tint. You may also notice tiny metal flakes. This is from the bearings breaking down and will cause a rear end noise.
Once the bearings are replaced the differential bearing preload and gear backlash need to be adjusted to proper specifications.
If pinion torque to rotate is low, tighten pinion nut in 6.8 N·m (5 ft. lbs.) increments until pinion torque to rotate is achieved.
CAUTION: Never loosen pinion nut to decrease pinion bearing rotating torque. If pinion torque to rotating is exceeded a new collapsible spacer must be installed. Failure to follow these instruction will damage the axle.
Ring gear and pinion are supplied as matched sets. Identifying numbers for the ring gear and pinion are painted onto the pinion gear shaft and the side of the ring gear. A plus (+) number, minus () number or zero (0) along with the gear set sequence number (2) (01 to 99) is on each gear. This first number (1) the amount (in thousandths of an inch) the depth varies from the standard depth setting of a pinion marked with a (0). The next two numbers are the sequence number of the gear set. The standard depth provides the best teeth contact pattern.
https://www.youtube.com/watch?v=oztrFKvMNSc
https://youtu.be/-EwUSpdwfA8 Let me know in the comments below if you think I should keep the grill or not. Easy enough…
I have 2012 Ford escape 3.0 when I start my car gas is leaking from muffler don't have pressure regulator…
Hi Jaxer, My name is Bruce XXXXXX. My car was bucking and jerking at idle and a little black smoke…
https://youtu.be/wzIyoLruvb8?feature=shared Jeep TJ Rear Bumper Removal Remove bolt attaching bumper to frame rail. On models equipped with tow hooks, remove…
