Chevy
Headlights Don’t Work 1984 El Camino
Chevy El CaminoHeadlights don’t work. Have parking lights, markers and tail lights but no headlights. Initial issue was very dim headlights, but now no lights at all.
My first thought would be a bad connection of some kind. It may be from some corrosion or rust, brittle wiring or loose connection. I will provide a wiring diagram for reference. Check for power at the light switch coming in and going out when the switch is pulled. No power to the switch, check the fuse and wiring between the fuse and the switch. Once that checks good move to the headlights. Check for good ground and then for power when switch is pulled. Repair as needed. Of course all testing should be done with a fully charged battery.
Headlights Wiring Diagram 1984 Chevy El Camino
zeker1
View Comments
  • Found the problem! It was a broken tan wire at the connection where the feed from the headlamp switch enters the connector to the high beam switch. Appreciate the response, it pointed me in the right direction.
Recent My Questions
BMW F30 Steering Wheel
2 months ago
Chevy Silverado Short Tube Header Install Video
https://www.youtube.com/watch?v=oztrFKvMNSc
3 months ago
Jeep Wrangler Angry Shark Grill, Keep it? -Video
https://youtu.be/-EwUSpdwfA8 Let me know in the comments below if you think I should keep the grill or not. Easy enough…
3 months ago
Gas is Leaking from Muffler 2012 Ford Escape
I have 2012 Ford escape 3.0 when I start my car gas is leaking from muffler don't have pressure regulator…
4 months ago
Code P1374 2003 Chevy Monte Carlo SS 3.8 liter engine No Spark
Hi Jaxer, My name is Bruce XXXXXX. My car was bucking and jerking at idle and a little black smoke…
4 months ago
Jeep Wrangler TJ Rear Bumper Replacement Video
https://youtu.be/wzIyoLruvb8?feature=shared Jeep TJ Rear Bumper Removal Remove bolt attaching bumper to frame rail. On models equipped with tow hooks, remove…
8 months ago
