94 Buick Oldsmobile. Harmonic Balancer.
The harmonic balancer in my Oldsmobile went bad. I bought a new Balancer and removed the old balancer. The bad balancer was extremely tough to remove. I rented a Pully Puller from my local Autozone. The Pully Puller wasnt big enough to remove the balancer completely. Therefore,  I used a socket as a spacer. I put the socket in the crank shaft (where the bolt goes that holds the balancer in place). I got the bad balancer off but got the socket stuck in the shaft. I tried drilling the socket to  smaller width and then hitting it with a pick and hammer. Those stainless steel sockets are tougher than i thought. Then I took it to my mechanic who tried heating it then removng it, no success. There is brass behind it so it cant get too hot. He told me to talk to a machinist and see what they could do. This car isnt worth much and im not looking to spend much to fix it. Does anyone have any advice and/or help with my problem?
tayhead
View Comments
Recent My Questions
How to Replace Thermostat 3.6L Chevy/GMC – Code P0128
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
1 week ago
Jeep Wrangler TJ 97-2006 Clutch Replacement
Removal & Installation Remove transmission. If original clutch cover will be reinstalled, mark position of cover on flywheel for assembly…
3 weeks ago
Fuel Pump Driver Module (FPDM) 2014 Ford Explorer 3.5L
Engine has no codes. Scan tool shows cam and crank correlation are good. Fuel pressure from pump is at 60…
1 month ago
Just put these sick headlights on my Jeep Wrangler
Headlamp Bulb R&R Warning: halogen bulb contains gas under pressure. bulb may shatter if glass envelope is scratched or if…
3 months ago
Hole in valve cover 2017 Hyundai Santa Fe
Intake CVVT came apart and blew a hole in the valve cover. How much would something like that cause to…
4 months ago
BMW F30 Steering Wheel
10 months ago
