Auto Repair Questions
Installed battery backwards E28 518i 5 series BMW (1986)
1986-bmw-518
Hello, instead of connecting the positive terminal of the battery to the starter motor, I connected it to ground. At first I did not see any spark because the ground terminal was disconnected. But when i approached the ground wire to the battery negative terminal a spark appeared. After fixing my mistake, the fuel pump does not stop when the key is turned to “start” position and there is no crank.
What is the most common fault that it is expected to have from my mistake? Fried ECU? Fried starter? Bad ground connection? Thank you
Double check your connections and then make sure the battery is fully charged. Check the related fuses and relays. Sounds like the fuel pump relay is stuck on. I don’t think you harmed the starter. If you hurt anything it would be the battery.
Alvaro Martinez
Recent My Questions
How to Replace Thermostat 3.6L Chevy/GMC – Code P0128
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
1 month ago
Jeep Wrangler TJ 97-2006 Clutch Replacement
Removal & Installation Remove transmission. If original clutch cover will be reinstalled, mark position of cover on flywheel for assembly…
2 months ago
Fuel Pump Driver Module (FPDM) 2014 Ford Explorer 3.5L
Engine has no codes. Scan tool shows cam and crank correlation are good. Fuel pressure from pump is at 60…
2 months ago
Just put these sick headlights on my Jeep Wrangler
Headlamp Bulb R&R Warning: halogen bulb contains gas under pressure. bulb may shatter if glass envelope is scratched or if…
4 months ago
Hole in valve cover 2017 Hyundai Santa Fe
Intake CVVT came apart and blew a hole in the valve cover. How much would something like that cause to…
5 months ago
BMW F30 Steering Wheel
11 months ago
